The issue I'm having is on a 2003 Silverado, 5.3 LS. Not long ago I had my PCM updated/reflashed and since then my 4wd-HI will randomly engage while I am moving at decent speeds. Once 4wd-HI engages, the only way I can get out of it is by going to AUTO then 2wd, but even then it will not work sometimes. When switching back does not work, I can feel 4wd-HI disengage from the front wheels, but the 2wd light will continue to blink and shortly after switch back to 4wdicon1.png. It's been happening more often and I'm afraid it will one day switch to 4wd-LOW at high speeds and grenade my differential transfercase.
I've read that it could be the controlicon1.png panel, but when it happens all the lights continue to work and I am not getting any dash 4x4 service message. The other is the encoder, but before I spend the money and time I'd like to get some more opinions from those more knowledgeable and experienced than me.
Thanks
Just paid $500 to replace my second bad actuator today. The problem starts as intermittent 4WD engagement and then it will not move back to 2WD.
You need to engage the actuator into 4WD every couple of months to keep it working properly is what Carl Black Mech told me today.
I joined this site today to learn how to change actuator myself next time. Good luck.
Thanks
ya dont go and throw parts at the computor controled t case ,,,,t case will not shift into 4 lo at speed ,,,,
you scan scan it for giggles and go from there ,no guessing
programming PCM has nothing to do with the TCCM
do not guess
Another instance in which I'm glad I got the lever actuated transfer case. Admittedly this isn't a very helpful comment.
agreed !!!
unfortunately people have stated that they like hitting little buttons,,,,car makers have provided this ,,,,at a cost when it chards the bed ,,
second paragraph is out to lunch ,,never heard such nonsense in awhile lol
What did you do to fix it?
I wish that I had better info on it. I sold the truck a few months back and now I drive a 14'. I had the receipts from the dealership also. I remember the first time that it happened I was driving on a lonely Hwy in the middle of Arizona. I drove it to a Chevy dealer and they replaced some sort of electronics ($600 worth). The next time it happened I was in my driveway. I thought that I was going to have to get a tow truck to get me to the dealer, because I was unable to get it out of four wheel drive. After I went into reverse, drive, reverse drive a few times it finally worked. I took it to the dealership the next day and they replaced the same electronics (another $600). At the time, I just paid it and went on about my life, so I couldn't tell you the exact details. I do know that that was my only problem with that truck for the 141,000 that I put on it before selling it. Sorry I couldn't be of any better help.
The actuator is easy to remove and diagnos. Seach on here for procedure.
he should really scan it first instead of doing ^^^^^^^^^^^^ maybe get pointed in the right direction ,,,
please dont tell people what to do before any codes are posted ,,,they WILL get side tracked and may spend money on misinformation ,,,,we cannot do that unless 100% confident
To be honest, it costs me less than half to replace the encoder ring than it is to have it scanned by a dealer. If I am wrong, then I still saved $55, since it can only be one other thing.
On the other hand, I refuse to pay $100 to simply find out what's broken on my vehicle. There is no reason with todays technology that you should need a multi-thousand dollar calculator to recieve system errors/faults. Not only that, but it allows mechanics to falsley state what is wrong with your vehicle. rather than you knowing directly before you visit. It really should be illegal in this day and age.
Imagine if Microsoft or Apple charged you $100 to display error codes on your computer or phone. There would be riots.
Edited by jcoast
I didnt tell him to replace it, I was saying the actuator is an easy part to troubleshoot.
Youre lucky at $100, my two nearest dealers charge $150
    Whit.the.COB
    Whit.the.COB
  • Who's Online   4 Members, 0 Anonymous, 376 Guests (See full list)
    • Even tougher is the 5.0 / 302. That's what this one has.    https://postimg.cc/Z9XRrCSg   https://postimg.cc/4n3F3yzY   Just realized I had the airbox removed in the engine pic, lol.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
