New (?) GM card sounds good
zacharywhitson
I'm lookiing into this and it sounds pretty good. The article is from October so I'm not sure if it's all still true. CHeck for yourself if your interested. Unlimited rewards that don't expire (like the old card) and no foreign transaction fee which is nice if you go between Canada or mexico and US.... anyway thought I'd share. I'm going to investigate further for my business card.
http://www.nerdwallet.com/blog/2013/gm-credit-card-offers-unlimited-points-drops-expiration-dates/
Sounded so good to me I got one to replace the crappy one that limits you to 1 or 2 thousand.
I still like the original one that you could get 500/yr up to 7 years and they didnt limit how much
you could use at a time. I remember when they had if you used it at a Mobil gas station they
doubled it so it was 10 % that was sweet.
