Chevyrcg’s 2014 Silverado LT Double Cab Build
Chevyrcg
Hey man that carbon interior is looking sweet! Would it even be worth trying for someone with no experience in vinyl, I wouldn't want it to look bad.
How does glow in the dark thread look in the sunlight? Grey or something?
Hey, carbon fiber is easy to do, just have to have patience.
The glow in the dark thread looks white in the daytime…. it’s cool stuff but remember it has to be exposed to light beforehand to glow. So you would have to hit it with the dome light or a light source for it to stand out in the dark. It’s a cool concept, but not as wildly effective as it sounds. The best scenario would be to have a backlight wired up in your truck and then it would really be something crazy.
  • Replies 56
That would be pretty sweet idk how you'd mount a backlight without it looking cheesy or such a way where it wouldn't get you in any trouble. The novelty of a little glow in the dark thread and a small black light is really appealing though.
I ordered a 60x12 roll of black cf and anthracite cf. I will test my skills on the bow ties with whichever color I like the least of the two before I take my talents to the interior items.
Yeah not as bad as I thought. Have you tried to take the covers off the ac vents? I did the driver and passenger doors, but I am having trouble getting anything else to come off and I don't know if I could put it on in place.
The only piece I took off to do so far was the DIC surround. That comes off easy, if you do a Youtube search for removing 2014 silver ado radio, the first part is how to take off the surround.
As far as the A/C vents, I can’t figure them out as well. I used a few of the panel removal tools i have and really put some pressure on them but nothing popped off. I was told that to get the trim off you have to take that whole corner off and that it is one piece. I was afraid of braking something so i stopped trying to force it off. I will do those pieces in place. Give it a shot, it’s not that hard. Use a hair dryer to “WARM” up the vinyl to work it around the compound radius’, do a little bit at a time and you should do fine. Do the DIC surround first off the truck and it will show you how to work the vinyl around the curves and radius’. Then tackle the A/C vents!
  • 1 month later...
Im very interested in your carbon work. I would love to do mine but feel I likely lack the ability still a very awesome look.
Do your stripes run down the roof and tailgate aswell?
Do it up man, I can sell you the vinyl to do it at my cost… I own a graphics company. let me know if you are interested!
Thanks for the compliments .
Sorry for the long delay! I am interested if you wanna message me prices. Do you think these material will work on my front emblem too?
I am interested in the same. I was thinking of doing my front and rear emblems.
No Stripes on the roof or tailgate, not considering the roof, just a waste of very expensive material, thinking of tailgate, but haven’t got to it yet.
Carbon Fiber is $3.15 a square foot, will definitely work on emblems.
Will definitely work on emblems, I did mine with flat black instead of the CF.
Sign me up. Do you have a picture of your emblem? Up close preferably.
That carbon work looks great! And the headrest logo's are awesome, totally makes me think classic Chevy :D
  • 4 weeks later...
I've got a double cab in leather. How much if I sent you all the headrest covers to do the red bowtie outline (Same layout you have)?
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 504 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
