K&N intake system '07-'13
This is an intake system off my 2010 6.2. Works well I believe the power claims. Original box and fully functional. See pics
Asking $125 shipped
Those HP specs must be wrong for the 5.3? It says 225hp on a 2010 Tahoe 5.3??? I thought my truck had like 330hp stock? Anyway, I'm interested if everything mounts up the same?
EDIT: Nevermind the HP question, it says that's in 2nd gear, LOL! I checked it out and it says it'll fit my 13. I'll PM ya!
    Brendan C
    Brendan C
  • Who's Online   6 Members, 0 Anonymous, 1,086 Guests (See full list)
