The return of.....
Torque Junkie
Yall know how it goes.....
But for those who don't, I'll re-explain. :devil: I'm going to put down a single word. The next guy comes in and put's down the first word that comes to their mind when thinking of the previous word. Yall got it?
let's see how this one goes. :D
My word........
Snow
Bury
And you know what the funny thing is, all but a few hours ago I was thinking of posting this.  I guess great minds really do think alike  (no jokes newbie, I know you'll say something)
