DRL's inoperative; do not work / quit working
I have 2008 Silverado with day time running lamps that just out of the blue quit working. the lower driving lights are my only lights. The high beams intially worked, as i switched over to see if i had another source of light. Then switching back to low beam / DRL's, the high beams only work on the "flash" sequence; by pulling turn signal back. I checked every single fuse in both fuse panels (under the hood & interior driver's side dash) and checked each relay as well. Placing a new relay in each location, and checking lights / DRL's, inop??!!
I have heard that if "high use" of the tilt wheel, will cause a harness in the steering cloumn to become unplugged. I have taken my lower dash off / knee bolster and top cover of my steering column, and all wires and harness look good, and connected.
My Cruise control quit working a couple of months back. the green light on dash, show active but no set speed continues.
The only mods to my headlights are i replaced the bulbs with Philips Crystal Vision Ultra H11 and the same on high beam with 9005. I switched the bubls back to the stock bulbs, still no low beam headlights / DRL's and high beams on flash to pass, as before.
HELP!!.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
