Remove Interior Door Panels?
Hello,
Im new to these forums, but hopefully someone can help me out here.. I am putting new speakers in the front and rear of my 2014 Sierra Double Cab. Can anyone tell me how to properly remove the front and rear door panels? I am afraid i will break them by pulling when there was a hidden bolt i was unaware of or something :(
Any advice would be great! Thanks!
I used a nut pick to get those two small trim pieces off, and a wide putty knife(3 inches wide) to remove the bigger hockey stick looking trim piece(starting from the bottom of the hockey stick at the end closest to the armrest and moving back and forth along the hockey stick until it popped off). I then removed the six screws that hold the door panel on. A small telescopic magnet can be useful to help remove one of the screws from the panel once you unscrew it all the way.
I pulled the panel off from the speaker side of the panels first and didn't break anything. A couple of clips stayed in the door and I used a plastic trim removal tool from a trim panel removal tool kit(6 piece) that I bought from Crutchfield that has a "V" in it to remove the clips stuck in the door. I didn't use that kit for anything else and I probably could have used a rag and a pry bar, screwdriver or needle nose pliers, but it did remove the clip without damage so I won't complain.
I then pulled up at the top of the door panel and ended up removing the weatherstrip and door panel all in one piece. To reattach the door panel to the door, I had to slide the weatherstrip out of the clips that attach it to the door panel and door. Then I used needle nose pliers to remove the clips that hold the weatherstrip from the door panel and slide them back in place at the top of the door. I then reinserted the weatherstrip back into those clips and was able to snap the door panel back in place after doing that.
I also had to attach the clips that hold the hockey stick trim piece in place to the hockey stick first and then insert the whole hockey stick trim piece to the door. I tried to just snap it back in place without removing these clips from the door panel, but I pushed one of the clips into the door panel when I tried and had to pop the bottom of the door panel off again just to get the clip. I used needle nose pliers to remove those clips from the door panel.
I haven't attempted the rear doors yet.
Hopefully everything will go smoothly and you won't have as many "learning experiences" as I had with these things. :lol:
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
