Tires
donb1226
Thinking about changing tires on 1500 all terrain. have 275/55/20 stock.
terra grappler or trail grappler
what sizes fit with no issues on stock ride hight no lift
I would go with the trail grappler 285/55R20, its by far the best looking tire out there and it will fit an all stock truck. Keep in mind the trail grappler will affect your mpg, ride and quietness of the truck. I have some 285/55R20 BFG AT's and my truck is all stock.
has anyone tried any wider than 285 on all stock truck
When I first bought my truck I installed a 2" RC leveling kit with some 295/55R20 Nitto Trail Grapplers. Even with the leveling kit there was a slight rub but nothing major. You can test fit some 295's on a stock truck, but if you do serious off roading I would not do it without a leveling kit. I removed the 2" leveling kit and put the truck back to stock, traded in the trail grapplers for BFG's only because I did not like the ride of the trail grapplers and the mpg loss I took with them on.
P.S. This post will probably be moved to the wheel and tire section by the moderator.
Id say the 285/55/20 to be safe, thats what I have read.
I am getting a 2 1/2 lift put on at the dealership when I pick my new one up and it looks like they are good with putting the 275/65/20 terra grapplers on there part of this upgrade from the standard denali tires/rims. That seems to be the max I can do without it rubbing, unless anyone tells me otherwise on problems. I think 295/55/20's were around the max as well, possibly 305's from someone else i remember posting.
You should be ok with the 285's with a 2.5" lift. IMO the wider stance of the 285's will make your truck look so much better over the 275's.
I have the Terra Grapplers on mine in stock size and love them, as said I didn't need the more aggressive Trail Grapplers and didn't want the loss in gas mileage as well
I care about the height more than the width, filling out the wheel well.
dobdabomb,
Here is a pick when I had some 275/65R20 BFG AT's and a 2" RC leveling kit. They did fill out the wheel well very good!!!
dobdabomb,
Great to see that, I have bf AT's on my Tahoe right now as I have had two sets and love them just wanted to try something new that wasn't mud. So that's why I went terra grappler finalizing with my dealer. A side of my wants to call and change to the Toyo AT2 extreme's. Friend has 35's on his ford diesel and they are nice looking. Decisions.
    liddlera
    liddlera
  • Who's Online   4 Members, 1 Anonymous, 368 Guests (See full list)
    • If you have actually done it, there must be some secret tool or method of accessing the hidden bolt head that both manifold connections have. Two of the three bolt heads are staring at you in the face from below but the third one is covered by shielding and as far as I know only accessed by removing part of the fender well lining to gain access to it and even then its awful to access or from what I had seen of someone fighting with it on a video.    There is a reason why even mechanics that deal with the awkward or risky business of undoing the exhaust at the manifolds have done the same method others are doing with these L8T by flexing the exhaust if need be or just able to slip the pan out as I did without needing to touch hardware or pry on the exhaust. By rights the two seals should be replace when those joints are cracked loose as well.
    • Actually it was a lot more controlled then I thought it might be and that isn't actually when I spilled some oil. I had thought prior of rounding up a couple of longer bolts with the same thread to swap out for a couple of the front edge pan bolts and then leaving one bolt left in the back but loosened off and then using a suction device to remove most of the fluid, that certainly would have worked and while I do have a couple of different devices I could have used to suck the fluid, now having done the job once I wouldn't even bother. I had thought of buying one of those pressurized vessels to suck or new fluid in and would if I was doing a job like this on a few vehicles but with one vehicle I just didn't bother and I have pail pumps as well I could have used assuming the hose end would fit into that less than roomy space but being such a thin fluid it pumped well with a quart type pump and just kept the hose into the trans and kept swapping containers and repeat.    What I would change to the method I did though was first jack up just the rear of the truck to put on jack stands to allow more oil to come out of the check plug on the front of the pan ( and as I did, I made sure to put that drain plug back in finger tight ) then follow through by putting the front on jack stands. Also that I would have used a larger sized drain pan in the sense of covering an area wider/longer beyond the transmission but I didn't have one and saw someone else on a youtube video using a masonry mud mixing tub and bought one at a hardware store to use in the future. The main oopsy  I did and why I spilled some oil was all my fault as I neglected to follow my own plan, I should have let down the pan as I did to drain out the front of it as much as would come out but then scooped out the remainder of the oil with the Dixie cup I had sitting there just for that purpose as by that point there is enough room to reach right into the front of the pan and just bail it out basically.
    • Pretty easy to just remove/drop the exhaust behind the manifolds. They're in no way hard to get to. Maybe 5min of work, and you get the opportunity to put some anti-sieze on them in case anything ever comes up, you eliminated the risk of snapping a stud.
    • I let the dealer do every other oil change simply so they can rotate the tires, which is a pita at home.
    • I addition, I won't have a pan full of fluid sloshing around to get all over the place.   I am putting on the Dorman pan with the drain plug. It looks like it is around the same height. I have one of these guys to make life a lot easier.   https://www.amazon.com/dp/B09CDXJCCT?ref=fed_asin_title&th=1
