Horrible experience with Performance Online (POL)
In over 30 years of ordering parts for numerous vehicles through catalogs and/or online, I have never had an experience like this. I found this company advertised in Chevy High Performance magazine, and even articles about the company and their products is in the magazine.
So I order a catalog and see (in catalog and on website www.performanceonline.com) that they have parts listed for my '74 Chevelle ('73-'77 GM A-Body). Specifically, I order the POL "hollow rear sway bar" and the complete set of tubular front control arms.
About a week later, to my surprise, I see a large box from Hotchkis Performance on my doorstep. I already know that Hotchkis does not make a rear sway bar for '73-'77 A-bodies. I open the box and sure enough the "POL" rear sway bar was drop shipped from Hotchkis and the direction say it is for a '69-'72 A-body, and it is solid, not hollow. I called Hotchkis and they confirmed that they do not make a bar for my car. I call POL and "Kraig" tells me that I must have ordered the wrong part. I explain to him more than a few times that the part number listed in the catalog for '73-'77 A-body matches the PN on my invoice, and matches the PN on the box from Hotchkis, so both the catalog and website are wrong. We leave off with him explaining that they will email me a return label for the bar.
A few days go by, no return label is sent to me, and I receive two boxes from Heidt's Hot Rod Shop. The Heidt's paperwork in the box says the control arms are for '70 to '81 Camaros. I call Heidt's and they confirm that these will not fit my car and that they do not make anything for 73-77 A-bodies. So I call Kraig back and he is not very courteous or helpful. I asked about the return label and he now says that they do not send return labels, and that I will have to ship the items back so they can process the refund. I ask for his email address and I send him an email summarizing the above and ship the items back.
UPS tracking confirms the items received and signed for at POL on April 3. I email Kraig to confirm receipt and he says he does not know because it is not his department and I have to contact returns. I email the main address and get a reply from "James Chadick" who somehow later becomes "Catelyn". After a series of emails saying they do not have my returned parts yet (I sent them scanned copies of the UPS receipts with tracking numbers, and delivery on April 3), they tell me on May 2 that my items were received and "We are very busy here this time of year, so please bare with me. I am hoping to have your refund done by late next week or early the following week."
I follow up on May 16th (still no refund) and they tell me to please be patient, it will be done on the 19th.
Two emails on the 27th and today go unanswered. Now I am calling my bank to dispute the charges, but don't know how I can try to get the $120+ in return shipping fees back. Stay away from these people. I learned my lesson and will stick with Summit Racing, PST, and AutoAnything.
Aside from contacting the Better Business Bureau, any other suggestions on how to proceed?
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
