Hey all im looking to get a high country grille possibly for my 2014 silverado ltz. If someone can point me in the right direction. Im trying to find the parts list for factory stuff, and possibly specifically the grille code.
Thanks
okay i found the number i believe 23173538,
Anyone one know of cheap sites to order from ebay is selling at 400$ roughly.
  • 3 weeks later...
I will have one for you. Just bought a High Country two weeks ago. It is practically brand new with 360 miles. I am installing a T-Rex grill. Message me.
  • 8 months later...
Will a 2014 High Country grille fit right into a 2014 WT Silverado? In talking to the local dealer parts guy, he mentioned headlight bezel fit to grille was different. ?? Has anyone made the swap?
I'd be surprised if that was the case. But then again what do I know :dunno:
Love the truck by the way!
Edited by jonny24
I bought a high country grille from the dealer cheaper than the ltz/z71 grille my truck was supposed to have
I got the High Country grille today and got it installed. No problems. The end, lower bolts are a bit of a pain to remove from underneath, however, if the upper bumper molding was removed first, the bolts could be gotten to from the front. When I reassembled, I bolted the grille in place and then pressed the upper bumper molding into place.
The older part number is 23173538, while the newer part number is 23473702. The one difference I noted, was the center post, which snaps into the truck frame is absent on the newer P/N. (Pic is from the older P/N)
One of the reasons I wanted to change the grille, was because the snow plow plugs wouldn't fit back through the honeycomb grille. I haven't poked them back through all the way, yet.
Note: I do have the chrome and black honeycomb grille, which i can make available, if you need one.
Edited by Dallas2
  • 5 years later...
Did those center post come with the new grille or did you uses the ones from the older one ?
