Aftermarket seat heaters?
Hey everyone, this is my first post here but I've been lurking for the last several months. Finally pulled the trigger on a white '14 Silverado LT 4wd crew cab short bed over the weekend! I traded in my 2010 extended cab 2wd with z-71 appearance pkg (I'll post more about my deal in the "Price Paid" thread later on).
Anyway, in order to get my deal done, I went ahead and gave up some things I wanted, knowing that I can take care of them later on. One thing I wanted was the heated seats. Obviously, I can get my own heaters and wire them up w/ a custom switch. However, I'd like to see if I can keep it factory looking by modifying my dash and installing factory switches to control the heaters.
My truck has the 2 buttons on the center lower part of the dash, for traction control and bed lights. I believe trucks with the heated seat option use the outer left/right spots for the switches...so mine just has like blanks in there. Any idea what it would take, or if its possible, to replace these with factory switches? Sorry for the small pic, had to grab one online because mine is at the Line-x shop today.
I've searched and come up with nothing helpful. So, please forgive me if I've missed an obvious answer. And thanks for the help to come and tons of help I've already received!
And also the heated seat button are not located there. Theyd be where the red arrows start on that picture (in the silver area)
Sent from my SM-N900V using Tapatalk
Ah, got it. I had seen other dashes with the buttons there, but couldn't tell what they were for. I guess I'll keep thinking about the best way to do this and maybe I can come up with something semi factory-looking. Or just make it easy on myself and hide them all together. Thanks for clarifying!
Actually if you pull off the bezel from the dash, there are wires that would plug into the switches for the heated seats. The wires attach to blanks on the inside of the bezel. Not sure what else is needed under the seats, and neither does the dealer when I asked. I am just waiting for the after market, like my 08 had. All the part numbers are available, heater pads, switches, and new bezel. Just not sure if its play and play.
Yeah I'm not sure where the other end of the wires are, or if there's an empty plug under the seat that would just need to receive the end off the heater pads. I'm curious about the bezel and switches, because that would be awesome. This was a $250 option from the factory...so I'm wondering how close to that it would end up costing using OEM parts and installing myself. I'll keep doing some research and report back when I get some #s.
Here are the part numbers I found. Still not sure if wiring harness goes under the seat from the dash. Dealer says if install, it needs to be programmed.
Bezel 22825711
Switch (driver)23147628
Switch (pass) 23147627
Heater cushion (need 2) 22878848
Heater back (need 2) 22878865
Nice! Thanks, guys! I'm not able to find a pic online w/ those part numbers, and the switches alone cost ~$60 each?! Maybe when the 15's come out, more stuff becomes available/visible for purchase. I'll definitely keep an eye on it. This might become a Fall project if I can pick up all the stuff ahead of time.
    • I went to order some PF63 oil filters from an on line GM parts source, and the blue PF63 oil filters seem to be getting phased out. They show the new part number as 19363567, which is a black colored AC Delco Silver product apparently marked PF63A. Some sites show a part number 12693541, which is a black colored AC Delco Ultragard Gold filter marked UPF63R.    I assume the UPF63R is the better one, but I’d be happy if I could just get blue PF63 filters I’ve been using.    Can anyone explain what is going on with the filter part number changes and any actual design changes?  Any other advice on buying OEM filters right now?  Thanks
    • thanks for coming back and posting what the fix turned out to be.
    • Only TAN I have for the product was at 5K in service miles and it was 2.71
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Will be attempting this sometime shortly and will likely make a youtube video out of it.   Note: please disregard fuse sizes. Main fuse will likely be 25A, all mini bus fuses will likely be 10-15A.   Here is my parts list: GM 84347199 - TC, Cargo Light, Exhaust Brake (useless to me unless I find a means to reconfigure), Aux 1 - 4. 12V 6 Way Pre-Wired Fuse Relay Box Kit with 4 x 40A 4-Pin Relays (link below - some mods required to make negative trigger)            https://www.amazon.ca/dp/B0F4KCS43B?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 Various wire sizes (12 AWG - red and black, 14 AWG, 16 AWG multi-colored bundle) Wire termination leads for X61A-X1 (unknown at this time) Crimp connectors/Soldering Gun Heat Shrink Split Wire Loom To be continued...    Cheers
