I went to back up today and received this error. Anyone have this issue and is there a reset or fix to it?
Sent from my SAMSUNG-SM-N900A using Tapatalk
This can happen when the backup camera harness becomes disconnected or damaged. Inspect the cable that enters the the underside of the truck bed (center of tailgate) for damage and ensure it is firmly connected to the distribution box just above the spare tire. Hopefully its just a dirty/dusty connection and simply needs to be re-seated or possibly cleaned and sealed with dielectric grease :-)
Thanks jmay, the truck is not even 2 weeks old so hopefully disconnected..
Try cleaning the lens, you get this message when its dirty or covered with snow.
I think I found the issue, a blown back up light fuse. I did the LED back up lights and they worked for 7 days, I guess something changed and they are the cause of the blown fuse. Replaced the bulbs with the regular ones and the fuse didn't blow.
I had this happen to me too, I just powered down my truck and waited a couple of min and powered it back up and the message was gone. Anyway, back up light? Man idk if that message would appear just for a reverse light, Bc that message stays on the display when in drive.
  • 4 years later...
Where is the fuse located?  Do you have a pic or diagram?  Same thing happened to me yesterday. :(
mine yesterday I went to back up and camera didn't even come up it just stayed on my radio it wouldn't go to a black screen it wouldn't give me an error message nothing I tried ...shutting the truck off going forward going backwards ..everything I tried just the radio was up never turned on ...now this morning I put it in reverse and it works don't know why...
  • 2 years later...
7 hours ago, Richt758 said:
I’m having the same issue now. Can someone tell me which fuse it is? Can’t seem to find it
Reverse light fuse is in fuse block in engine compartment and should be #33
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 283 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
