10" T-Rex Technology Air Suspension Lift on Dodge
TxDoc
"Well..it's starting to come together. I've been working on my 97 Dodge over the last 4 months. It's still a work in progress but, she's finally drivable again.
I have a T-Rex Technology Air Suspension Lift on my Cummins Diesel. This lift is fully adjustable. I can let it down to the point where it is essentialy 3" taller then it was stock. Fully extended, it is 10" taller over stock. I got some pictures up on my website finally.
Take a looky see and let me know what you think...and I know, the tires look small, but they are 35" and looked "big" before the lift."
Pics
Personally I think it would look ALOT better if he pulled off all of that chrome cladding crap and take off that ram thing on the extended cab section.  If you ask me, 10" is way too much.  I bet it looked good with the 3" lift....I wouldnt go any higher than 6" though.  I dont see any "real" use for having a lift of that size.  To each their own though...
I have to point this out though....doesnt his wife in that picture have a look on her face like "this is a bit rediculous..." LOL!
Yeah, but if you put big tires on it to fill up the wheelwells then you would lose the ability to adjust the ride height.
Also, I bet cotton stalks, corn stalks, branches and thorns play #### with those airbags.  (Not like it sees much off road use anyways).
It is an interesting concept though and in fact there is an article about similar suspensions in the Four Wheel and Off Road magazine this month.
    • It took me a minute, but I got it.😆
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
