Windshield washers not working
Went to wash the windshield today and nothing came out of the sprayer. Still have a full tank of washer fluid. I checked the fuse box and that's okay. It doesn't sound like the pump motor is running when I twist the switch to run the washers. The wipers do run when twisting the washer controls. My Sierra is 9 weeks old and has 1700 miles. Anyone else have this issue?
Check to make sure the pump wiring is snapped into place. I've seen that be a little loose and cause the pump not to turn on.
  • 5 years later...
Along the same topic lines, the windshield washer motor isn't working in my 2016 Silverado LT. The wipers work fine. I tested both legs of the fuse circuit while my wife held the washer switch on and neither has power. I tested the tester on the horn circuit and the tester was working fine. The fuse itself is okay. This is a new truck to me, but just out of factory warranty. Not sure which direction to look...
    1GIO44
    1GIO44
  • Who's Online   1 Member, 0 Anonymous, 954 Guests (See full list)
