Oil Pressure Gauge Acting Very STRANGE!!!
I have a 1994 2dr GMC Yukon 4x4 5.7 V8. The oil pressure gauge would normally run about 40psi when driving down the road and about 10psi on idle at a stop light. Well about a week ago it started going past the high 80psi reading to a complete 3 o'clock position far from the reading when you accelerate (not hard accelerating either) and when you let off the gas it would go to about 15psi. When you take off from a stop it would go back to the 3 o'clock position almost instantly. There are no lights lit up on the dash and the motor still runs like a champ. The oil pressure switch was changed out about 25,000 miles ago for a completely different reason. Any ideas???
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
