2014 Silverattle
madical1
I'm assuming that you're on Goodyear's? If so, there your problem. Replace with quality tires at 35 psi cold and check back. :)
I still have the factory Goodyear Wranglers on mine and I don't feel any vibration. I even raised the PSI from 35 to 42 and been running 42 with no problem, just a little stiffer ride as would be expected after raising tire PSI.
His name is Skip Greany, Fixed Operations Manager at Gordon Chevrolet
I would take them up on the offer to demonstrate other similar vehicles operating the same way. Do not wait too long, they will just say that they sold all the trucks like yours if you wait too long.
Who wrote this email to you?
His name was Skip Greaney, Fixed Operations Manager at Gordon Chevrolet, Tampa. Also, I think The salesman is Upset because I suggested that if this were a known issue it should have been disclosed before I closed the deal.
    contrabombarde
    contrabombarde
  • Who's Online   5 Members, 0 Anonymous, 1,417 Guests (See full list)
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
