creaky leafs
Annoying is the best way to describe it. Its fine at speed, but anything less then 30 or so, small bumps in driveways or parking lots, creek creeek creeeeeeek. Seems like its the drivers side leafs. Perhaps the bushings? I sprayed them with some fluid film. That just seemed to waist fluid film lol. Any other tips to get rid of the annoying squeak/creeeeek from my leafs??
ya think? I went over the mounting bolts for them, all seemed tight. and I swear it sounds like its coming from the rear wheel area
Spray the leaves and bushings with some ATF...it will creep between the leaves, acting like penetrating oil but still have some body. Even if its not the leaves, it should help the ride some.
As noted, usually creeking is from the body/bed moving on the frame.
and how does one stop the creaking from the bed moving on the frame. i have had 2 replacement set of springs and still have all the noises as described above
Been on the road, I put chrome steps on get the same crap. I torgued them to spec etc. I would bet if you have after market steps, they are the first place to start. I took mine off and the noise went away. I hate it, but live with it.
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 885 Guests (See full list)
