Oil pressure
Hello I have a 1996 Tahoe 5.7 had it for 15 years and noticed when I start it up cold the oil pressure is a little high aprox 60 psi than after it warms up it goes down to normal pressure aprox 42 psi since I bought it, my brother thinks something is not right, I have taken it across country no problems, is this normal or stuck regulator cold or?
Thank you for your time and response.
Ron
When cold oil is a little thicker,as it warms up to op temp it thins some.Yours is perfectly normal.I put a mechanical gauge in my burb a couple of years ago and it reads 60+ when cold and 40-50 when warmed up(above idle).When warmed up it has 20 or so at idle,normal.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
