Upgrading 2012 bumper
Hello
I am trying to research if it would be possible to upgrade a 2012 Sierra 4x4 slt bumper to the new 2015 style with steps on the sides?
I'm not sure if it matters but the truck has the easy lift tailgate as well.
If anyone can answer this or can point me in the right direction I would appreciate it! Thank you!
