XM Radio compatible with 2M/440?
My new vehicle ('03 Silverado 2500HD LT Duramax/Allison) came equipped with Bose XM Satellite radio.  In the literature it makes some vague warning about damage from radio transmitters.  I suspect this might just be some lawyers CYA boilerplate, but wonder if any of the gathered multitude have run XM radio and UHF/VHF ham radio in their vehicles?
ô¿ô  73, de Hans, K0HB
  • 4 weeks later...
Hi Hans
Just wondering if you tried your dual band radio with your XM radio. I an thinking of getting an XM radio and put the 2m rig in/out on occasion.
73 -Thanks
Mike K2MMM
Hi Hans
73 -Thanks
Mike K2MMM
Yes, I installed it, and it works just fine.  No interference to the factory installed XM-radio.  I don't know if you can tell from the photo, but the 2M/440 antenna is mounted at the middle rear of the cab roof, and the XM antenna is at the front right corner of the roof.  The radio is an Icom 2720, 50W, and I have it mounted on the left hand rear seat support.  Control head is just under the dual-climate-control knobs.
73, de K0HB
Yeah I can see the antennas.I have been thinking about throwing in the Icom 706mkIIg in there somewhere. Great rig
although I only use it on 6m at the base. Good luck w/the new truck. Looks great.
73 Mike
K2mmm
I have a 706-MKIIG in my RV.  Works good.
  • 4 weeks later...
Blacksilver,
Do you have any pics of your radio install or a closer one of your antenna mount.? I bit the bullet on a two week old truck and popped a hole in the center of the roof for a 1/4 wave larsen dual band that lets me pull in and out of the garage without hitting.  Right now I have a FT-90 mounted between the steering wheel and the center console under the dash right above my leg.  It works great but was eyeing up the 2720.  Also, looking at that same spot to locate it as you did.  Or might go with a '706.  Since you did a remote mount what did you do for a speaker?
Thanks.
Trying to get my list together for the Dayton Hamvention this year!
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
