GM 6" Oval Side Steps Installed
After much deliberation and research, I bought a set of the GM 6" chrome oval side steps for my 2015 2500 crew cab. If anyone is interested, I'll post a picture tomorrow.
In the past I had 4" oval nerf bars on my trucks that used the body mounting bolts for the install points. They were good bars but I have always had some level of concern about messing with the body mounting bolts and bushings for mounting steps and nerf bars. I also wanted a wide step this time. We need the functionality of good wide steps. My wife and I use our truck for towing our Airstream around the country and really need a good step for climbing in and out of the truck.
The install of the GM steps was extremely easy as compared to bars that use the body bolts for mounting. They are very sturdy and appear to very well made. No play in the step's structure (one with the truck). I bought them off Ebay for $525 delivered from a Chevrolet dealer in North Carolina. Purchased Monday morning and at my door on Tuesday morning.
Hi..Can You Tell Me the E-Bay Seller ..I Was lso Opting For These Steps ...But the Dealer Price For Acc...Is Out Of Control...Thanx..Tim
abernathy chevrolet in Lincolnton NC. I believe you will find them listed for 2014 1500 Silverados and Sierras. They are first class people to deal with. Below is a link to the listing. They have many other products at reasonable prices. They have an Ebay store and appear to do a brisk business. I have no affiliation with them other than being a satisfied customer. I also bought my towing mirrors from them.
22805442 Chrome 6" Side Assist Step Bars 2014-2015 Silverado & Sierra Crew Cab
  • 4 weeks later...
Might be a better choice than our Raptor 5" oval steps as they are a bit too close to the body to provide maximum utility. We do, however, like the price and the stainless finish which closely matches our AS. Would like to see that picture you indicated ...
    rayredbone
    rayredbone
  • Who's Online   3 Members, 0 Anonymous, 280 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
