Survey
Joe C
General Lee,
I believe I found it through a search. ???  ???
It was some time ago. I finally registerd and here I am.
The site will be a big help throughout ownership and mods.
Thankz
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
