3" spindle lift
skennel23
I have heard to stay away from 3" level/ lift kits as they will just add extra stress on front end parts and cause plenty of premature wear and tear on front suspension parts.
yea that is one of the things I am worried about. I have a 2wd so since I am starting out lower than a 4wd I was thinking I may be able to do a 3" leveling kit, or do the spindles.
spindles drop everything down... so they are better than a level, but that price is way to cheap to be reputable
Ah okay. Thanks for that info. I honestly didn't know. I have just seen people shoot down all other 3" lifts / level kits that have been brought up in the 2014+ suspension lift thread
  • 1 year later...
I'm running that spindle lift with John problems on my 2014 Silverado 1500 2wd 3" spindle 3" body lift and I am thinking about doing a leveling kit of 2,5 on top of that
Sent from my XT1080 using Tapatalk
