OLM set for dino or syn?
LaserBlueZ71
I have always run Pennzoil Ultra with NAPA gold filters in my 2011 5.3, the good stuff.
Here is what I am wondering.
Is the OLM system calibrated for normal dino oil, or synthetic oil? My monitor is down to 15% or so after 5 or 6,000 KM, not miles. I think it is a total waste of money to use $10 per L oil, then change it out every 3,000 miles.
Do you think I could safely change my oil once per year, and just reset the monitor when it nears 0%? I only put on 10 - 12,000 KM a year. My drives average 30 minutes each, 2 to 3 times per day. Mostly stop and go traffic with an average speed of about 70 KM/H.
Thanks!
If you did not have an OLM what would you do? It is just a gadget installed to remind the brain dead that they should change the oil once in a while. It does not take any actual samples of the oil, or even know what viscosity/type/grade of oil being run. It does provide a SAFE oil change interval though. Short changing the oil is always going to be the safe thing to do.
Back in the 70s we used to put a little box at the bottom of the dash with a little plugin thing that would burn out in x number of hours of engine running. Once burnt out, it would turn a bulb on in the box that lit up the stencil in the front of the box that said to "Return vehicle to [our dealer name] for servicing.". We would install an new plugin thing after servicing the car. Was a great way to remind people to service their vehicles. This was a predominantly farming community, and the cars were being driven by the wives. The trucks with the box rarely came back for service, but the cars usually did.
+1 for both above posts.
I would NEVER trust an electronic device designed by GM to tell me when it THINKS I should change my oil. I want my expensive equipment to last as long as possible, before becoming an 8 cylinder oil pump ....
Remember ... GM is in the business of selling NEW cars/trucks - not making them last forever. Same reason I would never run any GM fluids in my Chevy, or Polaris fluids in my Sportsman 800, or Yamaha fluids in my '74 RD350. I run the best of the best (in my opinion) synthetic oils, and change them based on oil analysis, or when I feel like changing them ... which ends up MUCH sooner than that OLM ever recommends.
I have an 05 Sierra with a 4.8 and an 03 Tahoe with a 5.3. I have over 225k on the 4.8 and over 204 on the Tahoe. I have run the better synthetics now since I purchased them , each had about 50k on them. I have run 7-9k between oil changes and both still run great with minimal oil useage.
I did an analysis once on each after a 10k oil interval and the verdict was, whatever you are doing, keep doing it, oil was great.
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,175 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
