What A blast!
TheScaryGuy
Man these things are fun.  My buddy has 2 of them, asked me to come riding with him today since there was no school.  5 1/2 hours of gas burning fun!  Then we broke out the tube and pulled each other through the trails.  His open field was fun to, just putting each other into 30mph whips, too bad the snow was so #### hard.  With the freezing rain about an inch of it was ice......many cuts and bruises later we were done...Definatly worth it.  :crazy:
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
