Leathers seats cracking!
The vinyl on the side of my driverseat cracked and split open (near the seat belt exit). Has anyone had this happen?  Is this a common thing?  My truck is a 2002 with 30k miles on it.  I am taking it into the dealer on Monday, I hope they don't give me any problems.  I haven't had the best luck with them so far.
The dealer should fix it.
My buddy at work, put a small "scratch" in his seat on his Tahoe with a rivet from his Levi's and the dealer replaced it for him.
Yes it is common. All my friends who have leather seats in their trucks are cracking also. That is why i got the cloth in my truck, why spend the extra money for something that is not going to look good in a few years. Don't get me wrong I love the look of the leather seats also but every one I talked to that had leather seats told me that they wish they had the cloth. I have leather seats in my corvette and I have had really good luck using the Zaino leather conditioner on it regularly, but I am not driving this car but once or twice a month so that helps the seats from being worn.
I had almost 4 years and 90,000 miles on my '99 Sierra SLT, no problems with the leather at all. They still looked great, much to my surprise.
I don't use any type of solvents or "treatment" for the leather either. Atlanta is hot in summer and the interior was charcoal, I was especially pleased with the comfort of them. A++
Would the catskin (I'm sure I spelled that wrong :jester: ) leather seats be a better option?
Do they work with the heated seats?
I use Lexol conditioner about once a month.  The seats actually become softer and more supple with age.  It's kinda spendy, but very effective.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
