Thunder Nationals!!!!!!!!!!
TheScaryGuy
My g/f got us tickets to go to thunder nationals!  She doesn't hate trucks but I know she doesn't care for monster trucks.   Well she knows the way to my heart......  :owned:  :owned:  :popcorn:  :D
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
