Bulb resistors
beetlebz
I've been toying with the idea of replacing my tail and/or brake light bulbs on my 14 silverado (as well as the rear turn signals on a prospective 13 Malibu) with led's to do double duty as warning lights. I know a simple wire-in resistor will fix the hyperblink, but will it also fix the in-dash bulb out warning? Or will I need some kind of vehicle specific resistor?
The resistor acts like a halogen bulb load, so the elctronics thinks the bulb is drawing fine. That is how the resistor works! So the in dash electronics doesnt know the difference.
I cant recall though if you pull the LEDs out and keeping the resistors in will still retain the ability to detect the bulb is out as an LED. I think it does, but dont count on it! I might check this when my marker lights comes in.
A load is a load is a load. If u wire in the resistors permanently, then the computer will always think the bulbs are fine, even if the LED burns out.
yeah, the load of the resistor alone might not be significant to act like a bulb. but with LED, it might, this is just my theory :D
I thought I did test this and it does trigger, but I cant remember for sure. Will test again when my markers are in!
    Selfman
    Selfman
  • Who's Online   4 Members, 0 Anonymous, 625 Guests (See full list)
