Color matched Tailgate Handle/Housings
Rewillia
Anyone here know of a source that offers/sells color-matched tailgate handles/housings, e.g. Summit white for the 2014 GMC Sierra with reverse camera option. I've seen the black matte finish ones on fleabay (eBay) that can be painted and I know some here have "plasti-dipped" theirs but I'm looking for a pre-painted to match and preferably metal similar to what comes on the Yukons or Escalades.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
