Wtb 2014 6" oem assist steps / running boards
blake23abe
Im in indiana, about 60 miles west of Indianapolis. Im at work now, ill get pictures sent to you tomorrow when I wake up.
If you take I-70 home to MN, (No idea if thats on the route or not) but youll go right past me.
Route goes right through Indianapolis so it wouldn't be too far out of the way. That'd be great if you could get some pics. Any idea what you're looking for price? Thanks
