Ignition-on power source in engine compartment?
I have searched and not found an answer. Anyone know of an ignition-on (non-continuous) source of 12v power under the hood? I know I can use a fuse tap in the fuse box, but is there an alternative?
Thanks for all of the reply’s guys, I really appreciate the help! :cheers:
I found the 12v ignition source!
It is located in the Mid-Bussed Electrical Connector in the driver side floorboard, behind the parking brake. It’s at port X-14 pin # 7.
Here’s a picture of the MBEC:
Here is a close up of the empty connection bay. Pin # 7 is a true 12v ignition source.
Thanks again for the reply's guys and I hope this helps someone else. :thumbs::seeya:
I used a fuse tap on the HVAC fuse, and ran that to a relay (less than 1 amp draw each)... So far my truck doesn't seem to mind, I think I powered 2 relays simultaneously on that circuit.
In the main load center, on the X2 connector, either pin A5 or B4 is an ignition-on power source. These two pins are connected to the aux battery relay on the TP2 option. I don't recall which one is the hot one, should be simple enough to test with a circuit tester.and a few terminal connectors.
Don't forget to disconnect the battery before you raise up the tray containing all the fuses.
    ottogriffin
    ottogriffin
  • Who's Online   4 Members, 0 Anonymous, 603 Guests (See full list)
