I was just in a head on collision....
Torque Junkie
.... with my brother
.... on my driveway!
http://www.redlineenterprises.com/crash/
He was coming down too fast for the icy conditions... 15, maybe 20 mph. I was going up at 10-15 mph. I saw him coming and was able to stop, but was unable to put it in reverse (whether from the deer-in-headlights effect, or fear of going off the edge behind me. He tried everything he could to stop but it was futile when he's going down an icy incline at 15-20 mph.
First off, we're both ok. He's really pissed at himself, and depressed, as I can immagine he is. I'm not upset with him... sh*t happens. I just wish I could have/would have put it in reverse and at least somewhat reduce the damage.
When he hit, I was stopped and my brakes were locked, he pushed me back about 5 feet. Granted, it was icy, but still yet.
The only damage to my truck is the bent bumper. His Blazer, on the other hand, is pretty f*cked up, as you can see in the pictures. The push-bar absorbed the entire impact and concentrated the impact more towards the center of the hood/radiator area, saving damage to the quarterpanel and headlights and battery, etc. My truck's ride height compared to his, my bumper would have hit SQUARE in the headlight/grill reigon if not for the push-bar to direct it to the center. I'm still not sure if it helped or made it worse, but it was damaged badly by the ipact.
His radiator was smashed into the fan, the A/C Condensor may be damaged, and we won't be sure until it's warm enough to test it, and the hood is toast. I don't think it's totaled, in the sense that we can probably find most of the body parts in a junk yard for pretty cheap.
Amazingly, no glass was broken. His 2 KC are damaged, but the glass remained in tact. The filiment came off the electrodes on both of them, but I believe KC makes replacement sealed beam/bulbs for their lights. The housings are dented, but in tact.
He learned a valuable lesson today. Ice + speed = NO STOPEY! He's only 15 (yes, you can get your Driver's License at 15 up here) and has alot of driving experience to gain, it's just too bad he has to learn in an expensive way. Neither of us have collision insurance on the vehicles involved
-Mike  :)
glad no one got hurt.  Glad your not to upset and tell him not to take it so hard.
Those first two lines wasn't exactly what I was expecting to read when I clicked on this topic.  Its good to hear that nobody got hurt, and you aren't to pissed about things.
btw, you got to love those real bumpers on the older trucks.  Try that with a new truck and it would have looked just about like the blazer.
Sorry to hear about the incident.
Got a couple questions....
1. What state do you live in? Do you live in canada?
2. (Sorry if this sounds stupid) Were the pics of the trucks taken at the accident scene w/out either of you moving the vehicles?
1) Looks like JP covered that :D.   I'm in Western Montana... bout 100 miles south of the US/Alberta, Canada border.
2)  Yes, the pics were taken at the scene, without moving either vehicle.....  that's where they both came to rest.
*sigh* ???  I feel so bad for the poor little guy.  There was really nothing I could have done to prevent it, but he's so depressed.  He saved up his allowance for months and worked slave labor at a go-kart track last summer to buy those KC's and the push bar.... just to have them smashed in a split second today.  He's so depressed and I just feel so saddened for him.  Granted, it was his fault for going too fast for the icy conditions, but I still feel so bad for him  :):D
-Mike
Thats an amazing impact for such a low speed collision.  Glad you're OK, sorry for the kid though.  That looks like he hit a phone pole.  Scary.
 I learned my lesson a few years ago when I rolled my beloved CJ-7 and had no collision.  Insurance would've written it off as totalled and I could've gotten paid.  Instead I had to swallow the loss and sell it off for parts.
 Be a good, albeit hard, lesson for him to remember in the future.  Costing ourselves is how we all learn -  ???
PS - nice driveway!
    RyGuy43
    RyGuy43
  • Who's Online   1 Member, 0 Anonymous, 537 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
