Looking for a damaged 14/15 Sierra headlight w/LED DRL
502ss
Basically looking for one to tear apart and figure out the wiring of the LED's
Maybe someone knows where there is one that has been in a wreck? Don't care if the housing is smashed just need the LED's and related circuitry working
Anyone!
Bump
Are the headlights different? The reason I ask is my 15 tahoe LT has the same headlights as the LTZ. The difference being obviously that the LTZ runs the LED strip for DRLs and the LT runs the driving lamps. I can switch to the parking lamps and run the LEDs but they aren't as bright. So far what I've learned is that the difference is in the BCM. The BCM has to be reprogrammed followed by a break pedal relearn at a significant cost considering, if I want to run the LEDs in the same manner as the LTZ. Perhaps this is the issue with the 14 / 15 trucks as well?
I think on the sierra if you don't have the LTZ (led DRL) then you don't have LED's at all!
For the most part if you hae a Sierra SLE you don't have the LED's, but on the All Terrain SLE's (not sure if it's the same on some other SLE's) they do have the LED's.
    FiLo
    FiLo
  • Who's Online   4 Members, 0 Anonymous, 598 Guests (See full list)
