Boo Yaa
jerseyTahoe
Well in about 1 hour I will be the proud owner of a 1999 Chevy Tahoe LT.  Fully loaded.  Black w/Burgandy leather, Heated seates, Barn Doors, Dual Heat/ a/c, You name it, it has it.  61000 miles. It is really nice.  I will post again later tonight.  Hopefully I will have some pics of it tonight as well.
Later,
Brandon
I love the old body style. Used to have a 99 2 door.  Sold it before depreciation took over, wish I still had it. :flag:  :devil:
Thanks guys.  I have pics but I still have to download them of the camera.  And then I have to find a free picture place.  I can use Yahoo and post the link in this forum right?  It is free right?  Well I will have the pics up tonight.  If not early tommorow morning.  Work Kinda gets in the way.
The hold up was I was trying to sell the car and the guy I was getting the truck from was waiting for the best deal at the auction.  You will all have a heart attack if I tell you what I got the truck for.  Well I will talk to you later.
Peace,
Brandon
Jersey,
If you want you can email me a photo or two and I'll host them off of my site for you.  PM me and I'll give you the address.  Congrats on your new ride-enjoy!
Well I am getting closer.  I have taken the pics and have them on the pc but I still have to email you.  Your addy woudn't work for me.  I will try again later.
Brandon
