I had a horrible dealer experience dealing with this issue. If any of you are under warranty you need to demand the dealership replace the HMI at the very least. A new head unit demand next if even a single issue arises after HMI. This an incredibly common problem amongst GM owners across all platforms. The dealers know the problem and they know the fix, they just put you off as long as possible because I’m guessing the parts are expensive even for the them.
The problem will not fix itself, it will not just stop happening. Have you ever heard of a electronic device that has issues and just makes itself better. They can do the updates, they can reprogram but it’s a equipment issue. The equipment is faulty and will not self-correct. Pulling the fuse, disconnecting the battery, etc will be temporary fixes, not long term.
if you are out of warranty you can try buying a HMI interface off EBay or elsewhere on the web. If you can’t get it preprogrammed you will need to take it in and have dealership or other service place do it. Probably gonna cost $150 for just the programming at dealership, stereo shop may be able to do it cheaper. Unfortunately if this doesn’t fix the issue you need a new head unit. I would absolutely not buy a used one, chances of it develop it he same issue is very high. New ones are like $800.
Your final option is to go through a company like Cruthcfield. I love that place. I priced out a new head unit, face-plate, all wires and harnesses to use the trucks existing controls, steering wheel, menu’s, etc. I think the total was like $850.
Don’t back down if your under warranty. Do some cursory searches and you will find a ton of vehicles with this problem. Print out 3-4 and take em with you.
Hope this helps.
  • 3 weeks later...
2017 Silverado 1500 LTZ - problem started about 1 month ago - blank screen - seems to be related to cold - when starting truck first thing in morning when below 30 degrees - screen comes back when passenger compartment warms up. Out of warranty period so I havent taken it back yet
  • 1 month later...
It has a very simple fix. Just as anything else some computers freeze and need to be rebooted. To easily fix this problem disconnect your battery completely from your vehicle for at least 30 mins. Once you have done this you can then reconnect the battery thus resetting your vehicles Ecu (computer). This is safe, cheap, effective with little side effects other than having to change the time and date back to your standard time zone.
  • 7 months later...
My truck has been doing this for almost a year. Dealer could get no code and when I shutoff the truck it would work again, for awhile. I drive it to the dealer the next time it did it and they saw it and still no code. Many months later they have replace the navigation module and antenna. It did it on the way home. Still waiting for fix.
    whenindoubtuseahammer
  • Who's Online   1 Member, 0 Anonymous, 364 Guests (See full list)
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
