New here in SC - 2015 Gear Swap Question
Clarken015
Update, I've not got the truck back as I'm adding some Hawk Brake pads & slotted rotors, but the truck now has 4.10 gears successfully installed & tested. Only thing left is to pick it up from Carlton Customs in Greenville SC. tomorrow. Then back to the Dyno/tuner to adjust for new gear ratio & speedometer correction!
  • 1 year later...
do you have any part numbers for the 4.10 gears or other parts used for install? Did you have to use the "make it fit" kit that made gears for the previous axles fit or did someone finally come out with a direct fit?
Honestly, I got tired of the paint PITA and sold it to a friend of mine. But the work was done by http://www.carltoncustoms.com/, give them a call, I'm sure they can help you as they had done 3 prior to mine at the time.
Once installed though, that truck was and is a beast!
    DLZ
    DLZ
  • Who's Online   1 Member, 0 Anonymous, 521 Guests (See full list)
