2014 Sierra Backup Camera Questions
Quiteman
I recently purchased a GM OEM backup camera . It is part number 22803702. It is the correct camera for my truck. I cannot use the plug that came with it because I need to cut it off and splice an RCA cable to it for an aftermarket Kenwood sterio. My problem is that I do not know what each wire is for. Can anyone positively identify the wires for me. It has 6 wires. Here are the colors.
A- 1 white wire
B- ! yellow wire
C- 1 red wire
D- 2 black wires
E- 1 brown wire
Thanks
A- 1 white wire
B- ! yellow wire
C- 1 red wire
D- 2 black wires
E- 1 brown wire
Thanks
well the 2014 electrical manual can be found here, but I didn't see any wiring info for the camera:
http://www.gmupfitter.com/files/media/photo/474/2014%20BBM%20Electrical%20section_10_18_2013_WIP.pdf
However I was tinkering recently with a similar GM van camera recently and it had these wires:
yellow was Video +
gray was Video -
black was ground
brown was Reverse signal 12v+
red was power 12v+
white was a Shield wire
When you cut apart the harness, you'll probably find that some of the wires are actually connected together, like the ground, Video - and/or the Shield wires.
I’d have to look up the pinout…what is the year make and model of the vehicle the camera is for?
2014 GMC sierra 1500. The camera part nomber is 22803702. That is the camera that the 2014's came with. This is where I found it in the GMPartsGiant.com online catalog. Thanks for your help.
Parts found for 2014 GMC Sierra 1500 Reg Cab (2WD) > Body Mounting-Air Conditioning-Audio/Entertainment > Camera System/Rear View
    juggernautusa
    juggernautusa
  • Who's Online   1 Member, 0 Anonymous, 417 Guests (See full list)
