whats your other ride?
EXJAY
here's the wifey's '00 XJ and me and my dads on going resto project of the '74 super beetle.
Just as long as you get one with an "extended front porch".  Though they look small, they can fit most anyone.
My wife drives a 2002 Honda Van, and I have a street bike (yamaha GTS1000) along with three soon to be street legal Honda Trail 70's.  And a Schwinn...  :chevy:
:werd:
I still have a Honda Z50R
Cannondale F600 Mountain Bike.
Dang, you beat me to it.  I've got a cannondale mountain bike as well, been laying dormant all winter so it's just about time to break it out, not sure what model it is though.
It's a little chilly in the winter months but it's all I can afford after putting gas in the V10! :chevy:
We have my wife's new Trailblazer but she doesn't let me drive it very often.... :flag:
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
