leaking master cylinder...
i think the gasket is going or the fill bottle is getting loose on top of the master cylinder because i notice a little brake fluid every now and then runnoff onto the inner fender well and if i move the bottle to the side a bit, it tends to seep out more. can it be tightned or any way of a easy fix? thanks
:banghead: According to my source, the reservoir is a push fit onto the master cylinder with two gromments to effect a seal.  I don't know if these grommets are available separately, but they should be relatively easy to replace, but I would bleed all four corners after refilling the reservoir.
Master cylinder rebuild kits are cheap and readily available at your friendly local parts dealer.
Only fix that I know of. Even if you can just find the grommets, I would recommend doing the full rebuild on the master cylinder while you are in there. Just to be safe.
They are not too hard to do.
Just my .02
    DLZ
    DLZ
  • Who's Online   2 Members, 0 Anonymous, 569 Guests (See full list)
