Heated Mirror replacement
i got a 2000 Silverado
Heated mirror Driver side doesnt work
can you replace just the glass mirror part????
or do you have to replace the whole mirror assembley??
thanks
yes you can just replace the glass.  Make sure you give the dealer your vin to order the correct mirror
Without your vin they cant order the correct mirror
they told me today they had to get the whole thing
they were pullin my leg eh??
first time I have ever dealt with them
is it an easy job to do??
can we do it at home??
Thanks
:chevy:
funny because i knocked my mirror out of the whole thing.  Hit the ground and shattered.  I called in they ordered one went to get it it was wrong.  They needed my vin reordered and it fit great.  Very easy to tke out and replace.  Should take about 2 min max.  There was like 11 pages of mirrors (different suppliers) in the parts dept computer.  The cost was $36 for mine (non heated).  Sounds like your dealer wants to make a quick buck and make you buy the whole thing.
Try another dealer or try http://www.partszoneonline.com email them they will get you a part number and a price (probably cheaper than locally)
I replaced mine with the Muth signal mirrors.  They are heated as well.
where did you get that?
I cant find it at GM Direct
Will the heated and Dimming work on mine??
I know it is heated, not sure if it is dimming
Thanks
:crackup:
I got those part #'s off a Google search.
I know the Heated RH p/n is good, I used it to order a new heated glass for my passenger side mirror.
Dimming won't work on yours without running additional wires.  My guess is the glass will need a switched ignition power feed and a wire run from the rearview mirror to the outside mirror.  The rearview mirror has an output for controlling other mirrors (it's one of those unused pins in the mirror connector).
When I upgraded the mirrors on my 01 Silverado from standard to heated I got the glass from my dealer. If I remember correctly the good guy price (as my parts dealer called it) was like $22.00 a piece. I think the real price is $30.00 a piece.
On my '02 Duramax, the right hand outside mirror cracked a week after I took delivery.  I went in to the dealer and asked the service person how much it would be for me to replace mirror...they told me that they didn't do that as they replaced the entire mirror assembly.  I was about to go into orbit when they told me it was under warranty.  The pulled off the entire assembly and replaced it with a new one....I've often wondered if a person couldn't purchase just the mirror.
    250.3k
    3CarSeatDad
    3CarSeatDad
  • Who's Online   3 Members, 0 Anonymous, 872 Guests (See full list)
