Hey Guys,
First time here and your site looks good. A lot of help on here. Glad to be here.
My 2002 1500HD's steering shaft sounds like it is bumping inside the column. I have been told you can pack it with grease but can't find out how. I have a few more issues that I will ask about later but now this is my complaint. I didn't see where I could do a search. Probably overlooked it. Any comments or suggestions will be greatly appreciated.
Have a great day,
Ken
Steering Shaft Lube Kit available from dealer at reasonable cost includes detailed instructions.
It is reusable.
Also may I suggest thread title be more succinct. Rather than "newbee", perhaps "Steering Shaft Bump" or similar to help in subsequent forum searches.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
