Trim below windshield fell in...
Has anyone else had this happen? I tried to wash my windshield and it was spraying just at the bottom, so I looked at it when I stopped for gas. I was thinking the washer lost it's aim, but when I got to the passenger side, I noticed the trim was down below the window. I pulled it back up, but the rubber was creased pretty bad and I'm not sure it will recover. I'll look at it tomorrow as this happened Tuesday I should know by now if it's going to recover. If not the dealer can fix it. I just thought I'd see if anyone else has had this happen.
It happens but is only a trim piece and not intended as a water seal. When mine falls below the bottom of the edge of the windshield I line it back up in place with a small plastic/nylon wedge tool. Anything else will likely tear or distort the shape of the trim piece. Noticed the gap on mine while doing my pre-delivery inspection when I purchased the truck new and my dealer changed it but it still happens on occasion.
When it did it again, I checked back with the dealer and they confirmed it is not intended as a water seal and will not result in water leaking into the cab of the truck. The plastic trim piece expands/collapses during temperature swings and while it may be considered unsightly, is considered normal.
Make sure to not push on that plastic trim piece as it is not a weight bearing piece.
Mine is creased from the winshield in the two spots it folded under. I don't think it will go back fully, but if it does before I go back to the dealer great otherwise they can replace it. I've never messed with that area in anyway so not sure why it happened. The only thing I can think that would put pressure there is highway speeds and auto car wash.
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
