It may be the windshield cowl trim piece. Check to see if the rubber on the top edge that touches the the glass is deteriorated & coming loose. A couple videos on this on YouTube
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
