brake lines
skyhighhooker
Hey guys. In a bit of a perdicament here you help would be great. I popped a brake line last night and didnt get a chance to size it. Do you know off hand what size the lines are from master cylinder to the abs unit. I dont have my vin handy sorry. its a sierra 1500hd crew cab.
Most lines on the trucks are 3/16" or 1/4" just going from memory, except for the main line headed to the rears (usually 3/8").
I just measured mine on my '07 and they're 1/4" O.D.
Let some of the guys that know for certain on your year model before jumping in though ... mine might be different.
thanx man, got it figured, I have the same as you, 1/4 form the master to the abs and tho the front brakes, 3/16 to the rear,
Nice. No prob. :cheers:
GM sells pre made and flared lines for pretty cheap, I'd highly recommend replacing all the lines with the kit instead of piecing in.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 750 Guests (See full list)
