14.73@95 mph CCSB LTZ on 20's w/5.3
SILVER SLED
It is a function of torque produced and so if you increase that value, the stall speed changes. My truck stock only stalled to 1800 but with forced induction i cant even get to the stall speed before pushing through the brakes, however it is somewhere over 2k.
Yes, the converter's stall speed is mechanically determined and will change with the engine's torque. And I'm telling you guys that speed is 2500+ with a relatively stock 6.2. The only thing holding it to 1500 RPM is the computer. Where exactly the 5.3 will end up I don't know, but it'll be alot higher than 1500.
So when I got home from work today.... This is in 2WD:
Every converter is different and certainly the DI 2014+ trucks have more torque than the last gen engines do down low. I cant say i am surprised. Ill take video when I get home from vacation showing mine and what happens with and without a timing cut from the computer.
A 6.2 has a diff converter. Usually though the more powerful motor will have a "tighter" converter in a given platform.
Oh man...you let off...I was just getting excited as I know what happens once you get past 4K or so on the tach. :driving:
Yeah, I had to as that was in my driveway....
Keep in mind the 2014's have much better brakes than the older trucks. I was able to hold it past 2500 there in 2WD, in 4WD it would have been even easier.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 1,315 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
