Wiring LED bed lights, does the wiring look good?
I'm wanting to wire some LED lights in my bed to a switch but wanted somebody with more electrical experience to let me know if the wiring looks good?
Since I am going to be connecting to the 12V at the trailer plug, do I need to put an inline fuse in even though it is already fused at the fuse box under the hood? Also, what gauge wire should I use?
Also, do I need to ground both the lights and the switch or just one or the other or just wire it up like the drawing?
Yes it looks good. Especially if you use LEDs because they draw so little. I like that your running it from the trailer pig tail. If I were you I would even add the switch and use both the trailer lights and ground all found in the 5 pin harness. But thats just me and I don't drive with my park lights on often. If you do the switch is a good idea.
I just did the exact same thing to mine yesterday . Except my switch had no ground , just used it to break the hot wire connection . Used the constant hot wire on the trailer plug . Grounded it to the frame . And used no fuse , since the trailer plug is on a fuse already ... Plus the fact these led lights hardly use any power draw at all.... I think it came out real nice , lots of light at night under my new bed cover.
J.D.
Fyi .. Love the bed cover I put on last week .they gave me free duel locks for being a member here .
I am planning on doing this also, but I thought would tap into the cargo light and use its switch. There wuld be only one wire as the ground could be at any point on the bed.
  • 6 months later...
I documented this exact install with pictures.
Installing custom (but inexpensive) Bed lights in 2013 Silverado
I started this project because I wanted to fill the (2) ¾” holes in the back of my bed. My thought process was why not add some lights in those holes and get 2 things for the price of one. I was able to locate ¾” LED lights on Amazon that fit perfectly into the existing holes. I added 8’ of 18 ga. Wire to each of the wires on the LED Bulbs (more than enough).
Now it was time to wire everything together and add a switch on the back of the truck somewhere that is easy to access. I found a WaterProof Switch on Amazon and had two spools of 18 gauge wire in my possession already. These ¾” holes are meant to bolt something in your Stake Pocket and since I have Bull Ring Stake Pocket Anchors installed, I will never use these holes. I removed the back anchors to gain access to the pockets and installed the LED’s with the extended wires and routed them through the hole in the bottom of the pocket. I then routed the wires down and along an existing wire loom and tie wrapped it to the loom on both sides and had them terminate near the 7-wire trailer connector.
I did lower the spare to give me more room to maneuver under the bed
I removed the existing electrical tape on the end of the wire loom and pulled it away from the wires. I then cut about 4” off the end of the loom and then re-attached that 4” piece to the wires all the way at the end giving me 2” to 3” inch window to attach the wires and switch to. In the Trailer wiring harness the Red with black stripe is the Positive (+) and the White is the Ground (-). The LED lights have a positive (+) wire which is Black and the negative (-) which is White. Since I did not have a spool of White wire I used Red to extend the White wire. I chose the Trailering Wire harness because there is a constant power source. I used a 3M connector to attach the ground (White wire extended with Red) to the White wire in the loom.
Finally I drilled a 3/8” hole in the plastic portion of the rear bumper to mount the switch.
I used crimp connectors to attach the Black (+) wire to the switch and added a short piece of black wire to the other wire from the switch to extend it and attach it to the Red w/Black Stripe wire in the trailer harness. Push the button and now you have light.
I purchased a 16’ strip of LED lights that I am going to install under the bed rails so it lights up the bed completely. I will use the wiring I put in already and simply attach these strips to it as LED lights draw very little amperage. I will update the instructions once that is completed.
Here are the lights I ordered from Amazon last night.
http://www.amazon.com/gp/product/B00WJN4OO4?psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s00
What size wire should I use? Do I need to fuse the wire from the trailer plug to the switch since the trailer plug is already fused at the underhood fuse box? If so what size fuse?
    tararebecca
    tararebecca
  • Who's Online   4 Members, 0 Anonymous, 626 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need.webcrimsNY
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
