Mud Flaps
I have a full set of mudflaps that have the GMC logo and are the grained finished. Part numbers 22894860 and 22894866. These were never installed on the truck. Selling because the right rear flap tries to use the same space as my exhaust.
I would like to get $70.00 plus shipping. I will put a pic when I get off work.
  • 4 weeks later...
  • 3 weeks later...
Did you ever sell these?
