Photoshop Request
jkul21
I want to put the high country grille in my LT Z71 but am not sure how it is going to look with the non projector headlights can someone photoshop in the High Country grille onto my truck?
Also if you could black out the bowtie just becuase i would plan on doing that.
not sure if this one is possible but the lowest piece of plastic in the middle of the bumper that is that silvery grey color I want to see what that looks like on my truck with the current grille if i were to paint it diamond tricoat white or just plain black.
I like both...although I have to admit I really like the grills on the Z71's as it is..just the right amount of chrome...IMO at least.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 1 Anonymous, 1,163 Guests (See full list)
