Start Knock....
Hey All,
My 99 Silverado with the 5.3 has started a nock/tick problem, almost like a lifter has leaked down, it quits after about 10 seconds of idling, usually only does it after truck has sat for about 4 hours or longer..   Is this what they are calling the famous cold start knock?  Would an engine cleaner, that you put in your oil, possibly help?
Thanks!
Matt
The cold engine tick that most 99-02 trucks have is caused by a design change in later model engines (they have removed the piston skirt to reduce rotating weight) which most have seen was a pretty lame idea, they claim this noise causes no engine damage and does not shorten engine longevity, which seems to be true (I have seen quite a few with over 200,000 miles)it's is just plain annoying
The second cause is when these engines start to get some miles accumulated, the oil entering the PVC sytem starts to bulid up carbon on the valves and pistons,the repair for this is to use a top engine cleaner that is put into the engine through a vacuum source(the booster hose) it it is best to get this product from you local GM dealer for best results,or have one perform this procedure for you (if you decide to do this yourself e-mail me I can give you pointers for best results)
Sorry for the rant,hope that helps  :banghead:
Matt, I have heard of using the product "sea foam" for cleaning the lubrication system but dont know how it works or if it is meant for carbon removal.
When using GM "Top engine cleaner" you want to get the engine up to full operating temp, have someone hold rpms around 2500 without letting it stall out as you add the cleaner into the vacuum system (a small funnel works well in the booster hose) or through the throttle body on early engines (slowly add the cleaner as not to flood the engine), as you reach the bottom of the can try to stall the engine with the last bit of cleaner or have your helper cut the engine off as you add the last bit, Now, the most important part is to let that last bit soak into the carbon thats in engine for approx 20min or more if wanted (dont let the engine get cold),after the wait period warm the engine and do as the say with a rental car, DRIVE IT LIKE YOU STOLE IT!! to blow out the loosend carbon.
As you will find out this will cause the vehicle to "smoke like a freight train" while cleaning, so PLEASE do this in a well ventalated area!
Also, when adding that "last bit" of cleaner I talked about dont go overboard and add so much that it floods the spark plugs or hydo-locks the engine!
Best of luck, Derek   :thumb:
Disclaimer.... apply at your own risk, not responsible for problems that could occur  :banghead:
Just curious, how much is the cleaner at GM?  Sounds pretty easy..  another question... i have installed a vaccum gauge, hooked it up on the very top of the intake..  it has a small line..   could i just take this line off and put it in the bottle, and let it suck it out?  or would that be sucking it to fast?
Thanks!
Matt
I would call GM customer service, and see if you can't get a free extended warranty on the engine.  Several people have had good luck getting GM to extend the warranty on the engine to 100K miles.
the top end cleaner should work, but most likely, the knock will eventually come back...  :banghead:
I think i will try that, shanners..  Do you have a number i should call to check on getting one?  i am going to try the top engine cleaner this afternoon, when the engine is warm, and let it set for about 5 minutes..  would still like to have the ext warrenty though     :banghead:
Matt
This number is from my owners manual:
Chevrolet Customer Assistance Center 1-800-222-1020
I don't know if that is the phone number that others have called, but it sounds like a good place to call to get the ball rolling...
    JimmyB4
    JimmyB4
  • Who's Online   0 Members, 0 Anonymous, 621 Guests (See full list)
    • Are you going to take long trips in it?  If so, try out the seats in the various trims. For me the lower trim level seats were not comfortable.
    • I have a 2016 that I bought new and still own. I'm around 129,000 miles now. The biggest problem was a transmission failure about 2 years ago around 95000 miles. No warning, just failed while driving down a back road. A reman GM transmission installed and it's been fine ever since. A few other minor problems along the way. I am in no hurry to replace it. It's been paid off long ago and do plan on driving this as long as I can.   I will admit I am leery about all the additional electronics in the newer models and feel that it is just more potential problems. I think there's actually more than I would have wanted in this 2016 but so far so good. I think even if something major like lifter failure happened, it would still be cheaper to at worst, drop a new engine in than buy a new vehicle.
    • I’ve own several successful businesses. I’ve bought homes and lived in different states. I’d witness several generations buy homes and survive in different economic circumstances. You get awful sippy when people have different experiences than you do. You live a life. I’ve lived a life. It seems our experience has been different. You can point out generalized statistics. Some people learn how to thrive when the odds are against them. Living in different states does make a difference in a persons quality of life and economic outcomes and opportunities. That’s a fact Jack. It’s my truth, my life. Hard work and long hours the right environment made my families life easier. And yes moving to a different state increased the odds of that happening. Stats are generalized. People who thrive don’t make excuses. They beat the odds. Others get mad and point to those statistics. I guess that’s you. My post pointed out how you helped people beat the odds. Somehow your panties got in a wad. Go figure.
    • Good question, I don't remember for sure but I believe it was the HD. I will check and get back to you.
    • Point of the post sir was that while both wages and cost are rising EVERYWHERE; the cost is rising faster EVERYWHERE than the ability to buy EVERYWHERE. We're not going down the location rabbit hole. I'm aware of what economic migration is. I've lived in four states including Texas.   It's what "Purchasing Power" means.   I'm not telling you what I think. I'm telling what the government, your government, data shows.   It wasn't an argument. It wasn't a suggestion. It was a statement of FACT. You are absolutely entitled to your own opinion. Your not entitled to your own facts. If you and I were, they wouldn't be facts.    fact /făkt/   noun Knowledge or information based on real occurrences. "an account based on fact; a blur of fact and fancy." Something demonstrated to exist or known to have existed. "Genetic engineering is now a fact. That Chaucer was a real person is an undisputed fact." A real occurrence; an event. "had to prove the facts of the case." The American Heritage® Dictionary of the English Language, 5th Edition • More at Wordnik   If you'd like to disagree call your Senator or Representative and let him know his departments are in error. But you and I? We are not doing this.
