Towing capacity with bigger tires (35x12.50 r20)
Cam I tow my fifth wheel with this tire size safely? I have the stock 20 inch wheels but I am going to change them to aftermarket next week. I would only be towing the fifth wheel about 1000 miles a year if even. Thanks for the help
If the load rating of the tire is the same as the load rating on the factory tires, then the towing capacity will be unaffected. Same for if the load rating was higher, the towing capacity and payload would be the same that is on the sticker on the door. That number does not change if the tire load rating matches stock or is higher. IF the load rating is lower, then the tires would not meet the factory load ratings, and payload and towing numbers would drop due to the tire load rating.
For example, a 35X12.50R20 Nitto Trail Grappler has a 121 load index which is the same as the OEM Goodyear SRA 265/60/20. That load index or higher and towing would be fine.
Only thing I would really be concerned about is the load capacity of the wheels you purchase.
    Bert 22
    Bert 22
  • Who's Online   2 Members, 0 Anonymous, 776 Guests (See full list)
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
